Activity › Forums › Media 100 › problems exporting xml media100 for After Effects
  • problems exporting xml media100 for After Effects
    Posted by Harrie Loggon on November 12, 2008 at 12:28 pm
    Hello,
    I got a problem with my xml export for after effects.
    When I use the timeline A and B from my master timeline, After Effects does’nt recognize the B timeline. It only reads the A timeline, so i got a half edit in After Effects;)
    does somebody knows how to fix this problem?
    I use Media100 v13 and After Effects CS3
    Joyce Woodworth replied 17 years, 10 months ago 4 Members · 4 Replies
  • Floh Peters
    November 12, 2008 at 1:29 pm
    First, did you install the newest AE Importer plugin? Copy the AE_XML_Project_Importer.bundle from your Media 100->Adobe AfterEffects Plugin folder into Adobe AfterEffects CS3->PlugIns->Format, and replace the older copy that may be there.
    Second, there is a bug that in some cases does not export the XMLs correctly. One thing you can try (in case it does work on your timeline) is to move your clips to Va, or to extend your outgoing clip on Va into the incoming clip on Vb. As far as I know this is something that is very likely to get fixed in an upcoming version of Media 100.
  • Harrie Loggon
    November 12, 2008 at 1:43 pm
    Ok thanks. I did Copy the AE_XML_Project_Importer.bundle but it doesnt work either.. I moved the whole edit to timeline v1 and v2.. its not the easiest way, but its the only way it works good..
    thanks for the quick post!
  • Wickham Strub
    November 13, 2008 at 12:07 am
    Yeah, well… Floh was quick on that one ’cause he’s the one that found the bug for us. It’s actually a bug that’s been lurking in the code for some time now. Strange how something can be out there like that for a while and then, all of a sudden, a bunch of people stumble onto it at the same time.
    A permanent fix for it should be rolled into an update sometime soon.
    ~Wick
  • Joyce Woodworth
    November 15, 2008 at 6:01 am
