Activity › Forums › Adobe Premiere Pro › Problems Exporting video to Tape ( cs3 and cs4)
  • Problems Exporting video to Tape ( cs3 and cs4)
    Posted by Evandro De oliveira silva on September 3, 2009 at 4:07 am
    Hi Guys!
    I hope somebody can helpme with this.
    directly to the point:
    I cant export a video from timeline to tape through Firewire.
    I CAN import tapes without any problem.
    But when I need to export to tape, CS3 renders the video, sets the camera to record, but in the camera just a blue screen.
    – The timecode on the cs3 preview dont run.
    – The playback settings are set to 1394 preview AND export, but no image on the camera.
    config.
    Windows vista x64
    premiere pro cs3/cs4
    sony handycam DCR-HC48
    mobo: MSI p45 Platinum ( firewire onboard)
    Clyde Schnitz replied 17 years ago 3 Members · 3 Replies
  • Mike Velte
    September 3, 2009 at 10:35 am
    Is there a menu option in the camera = DV-in??
  • Evandro De oliveira silva
    September 3, 2009 at 1:33 pm
    Theres is not a menu, but it shows DV-in/iLink in the display
  • Clyde Schnitz
    September 10, 2009 at 1:11 am
    I was having a similar problem with a Canon GL2. The solution was to go into sequence > sequence settings > playback settings…, and change the Realtime Playback and Export – External Device: from none to DV.
    I remember on my old Sony digital 8 camcorder I used to have a lot of problems with firewire, and I think I remember reading that people who had Sony computers didn’t have the same problems. When I finally switched to Canon on the same computer the problems went away. If you are still stuck you might try to export to another camera.
