Activity Forums Adobe Premiere Pro Problems exporting to tape
  • Problems exporting to tape
    Posted by Will Gaffney on July 7, 2006 at 2:29 am
    I have shot a video using my Sony FX1, edited it using Premiere 2.0, and now I wish to export it back to tape via the fire wire cable.
    The movie was shot and edited in 16:9, but when I export it back to the camera it comes out in 4:3 and the picture is vertically stretched (or horizontally compressed). I have reset all settings on the camera which didnt alter the result, so I believe that the issue is Prem Pro related.
    Are there any settings on PP2 that I may be unaware of that I need to adjust so the exported image is in 16:9?
    I have done this before using the same camera, but an older version of Prem Pro and did not have this issue.
    Any ideas?
    Jfmartin replied 20 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Aanarav Sareen
    July 7, 2006 at 5:02 am
    Did you shoot the footage as DV or HDV? What are your project settings? Please provide more detail regarding your project.
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Will Gaffney
    July 7, 2006 at 5:06 am
    The project was shot in DV and edited as the same. The camera is also set to DV when I try to export the movie to it.
  • Aanarav Sareen
    July 7, 2006 at 5:11 am
    That doesn’t answer my question. What are your project settings?
    Aanarav Sareen
  • Will Gaffney
    July 7, 2006 at 5:25 am
    I’m not really sure what you mean by project settings but I guess this might be it: D1/DV PAL 16:9 Widescreen (1.422)
    I was the only thing of relevance I could find.
  • Brett Howe
    July 9, 2006 at 8:15 am
    OK
    The FX1/Z1 lcd displays HD 16:9.
    If you are sending a 16:9 SD job to the camera, then yes, it will be in a 4:3 window, but anamorphic (tall and thin).
    This is normal.
    Any DV format you send to the camera will be 720×576 pixels, 4:3 or 16:9.
    I think you will find if you do a test, record a few seconds, then digitize this, with 16:9 settings, all will be fine.
    Cheers
    Brett
  • Will Gaffney
    July 10, 2006 at 1:42 am
    This doesnt make sense to me as I have done this with previous videos using the same camera, but did not have this problem. It only seems to have arisen since I went to PP2 from PP1.5
    I need to export the footage to tape so I can have it converted to Beta SP to be played on Television. Its really important that I figure out a way to get past this.
    Anyone else with any ideas?
  • Jfmartin
    July 11, 2006 at 5:18 pm
    Export to JVC HM-DH5U DVHS tape deck from premiere pro 2 with 1289 by 720 30p stream no problems during playback on the dvhs deck.
    Any attempt with 1080i or 1080p transport streams from Adobe Primere 2 Pro yields a video that has mozaic like blocking and interrupted sound when played back on the JVC DVHS deck.
    Any ideas as to what the problem might be?
    TIA for any response.
