Activity › Forums › Avid Media Composer › Problems exporting qt movie DVCPRO in AVID
  • Problems exporting qt movie DVCPRO in AVID
    Posted by Kadeh Ferreira on October 21, 2009 at 3:11 pm
    Dear,
    I had a problem exporting timelines AVID mc qt format for movie compression DVCPRO. Once converted the image appears milky.
    Does not happen when I use the same option as source, Only in that case the image appears slightly flattened.
    Can anyone help?
    Thank
    Kadeh ferreira
    Steve Schroeder replied 16 years, 11 months ago 3 Members · 2 Replies
  • David Braswell
    October 21, 2009 at 3:36 pm
    As far as I know, there are gamma conversion issues when exporting directly to DVCPro. The only way around it I’ve found is to manually adjust brightness and contrast in Quicktime’s “filter” setting before you export. I have to do this for a client who makes web video from DVCPro files.
  • Steve Schroeder
    October 22, 2009 at 5:11 pm
    We just went through the same thing, our Full Size QT DV/DVCPRO outputs were washed out. Adjusting the QT filters (Brightness and Contrast) are a good suggestion but in our case changing the capture setting from RGB to 601 fixed things. HTH Steve
