Activity Forums Apple Final Cut Pro Legacy Problems exporting multiclip sequence using Compressor
  • Problems exporting multiclip sequence using Compressor
    Posted by Claude Lavallée on March 10, 2011 at 11:15 pm
    I’m trying to export a 1hr20min multiclip sequence using Compressor, but the progress bar in Compressor doesn’t even begin and I don’t get an estimated time.
    I’ve only got two angles from cameras both shooting DVCPro50 at 29.97fps for 740 x 480. I have four audio channels and have added a few lower thirds, then rendered the audio and the video. Pretty straight forward.
    I’ve edited half a dozen multiclip sequences in the past, and exported them all using Compressor. The Compressor settings I use are H.264 LAN, H.264 800Kbps and H.264 300Kbps for Quicktime 7.
    I’m on a deadline, so I’ve decided to export using Quicktime Conversion for this time (that’s working), but I’d like to know why I can’t export using Compressor. Any ideas?
    Claude
    Mac OS X, version 10.5.8
    2 x 3 GHz Quad-Core Intel Xeon
    7 GB 800 MHz DDR2 FB-DIMM
    FCP 6.0.6
    Claude Lavallée replied 15 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
