Activity › Forums › Apple Final Cut Pro Legacy › Problems exporting a stop motion animation in final cut pro as a DV PAL file.
  • Problems exporting a stop motion animation in final cut pro as a DV PAL file.
    Posted by Bradley Bailey on August 24, 2012 at 7:19 pm
    Hello,
    I have a problem trying to export a stop-motion animation from final cut pro 7. My client has requested a DV PAL export but every time I export it, it squashes in from the sides and the quality is bad.
    I use a canon 600d to take the photographs at: 3456 x 1944.
    My sequence settings are…
    Frame size: 1920 x 1080
    Aspect ratio: HDTV 1080i (16:9)
    Pixel aspect ratio: square
    Field dominance: none
    Editing time base: 25
    QuickTime video settings are…
    compressor: apple prores 422
    Quality: 100%
    How do I export this correctly? What am I doing wrong?
    Thank you,
    Bradley
    Bradley Bailey replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
