Activity › Forums › Adobe Premiere Pro › Problems Exporting 50i Video
  • Problems Exporting 50i Video
    Posted by Paul Walsh on February 4, 2014 at 9:10 pm
    Hullo!
    I’m having some problems when I record at 50i in my camera and then try to export the file the same way in Premiere. A picture is worth a thousand words of an illiterate fool:
    Clip imported into Premiere:
    Same video exported at MPEG2 1080i 25 in Premiere:
    I’m temporarily using a borrowed JVC HM100 until I hope the more user friendly Canon XF100 arrives this week, but I have had a lot of problems with the HM100 not importing well into Premiere despite it having native MOV files. I don’t know where I’m going wrong.
    Thanks for reading,
    Paul.
    Massimo Alberto croce replied 12 years, 7 months ago 2 Members · 5 Replies
  • Massimo Alberto croce
    February 5, 2014 at 3:40 pm
    It’s is normal, because you see interlaced footage on a computer monitor. Premiere use only one field in canvas or source monitor, in an exported QT (on a computer monitor) you see both field. What about the exported footage on a broadcast monitor (or television)?
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Paul Walsh
    February 5, 2014 at 8:58 pm
    Hi Massimo, thanks for your reply. But I’m not sure it’s what you say, this is really really exaggerated and I don’t think it compares to other videos that I’ve seen on Youtube recorded at 50i (https://www.youtube.com/watch?v=xKDB6y5zmDc).
    It’s like it thinks its 1080i but it’s really a different resolution, that’s how bad the image looks. My XF100 arrives tomorrow, so I’ll have a look at what happens when I import footage from that at 1080/50i.
    February 6, 2014 at 8:43 am
    Hi paul. this effect depends also from camera movement. more the camera moves, the more the effect will be visible. I you publish on youtube, try export a de-interlaced movie.
  • Paul Walsh
    February 12, 2014 at 12:36 pm
    Hi again Massimo. If I deinterlace the film it looks fine, but itsn’t that effectively turning it from a 50i film into a 25p film?
    February 12, 2014 at 7:50 pm
    [Paul Walsh] “If I deinterlace the film it looks fine,”
    What you mean?
    What do you do to make this?
