Activity Forums Apple Final Cut Pro Legacy Problems during Import after Capture
  • Problems during Import after Capture
    Posted by Antonio Aguirre on February 13, 2007 at 8:54 pm
    The program that I captured is a DV Cam and I captured it off of a Sony DSR-1500A. The program was about 3 hours long. The problem that I’m having is that when I drag in the file onto the timeline the program is only about 46 seconds long. I feel like I’m missing a setting or check box. If you could help me out that I would be great. Thanks for the help!!!
    Paul Coull replied 19 years, 6 months ago 2 Members · 6 Replies
  • Paul Coull
    February 13, 2007 at 11:48 pm
    Did you do a capture now and were there any timecode breaks. Also check your captured movie file and see how big it is (i.e. MB or GB).
    grafxflow
    grafx that flow!
  • Antonio Aguirre
    February 14, 2007 at 3:03 pm
    There were timecode breaks in the capture. And the size of the file was 39 GB. Thanks.
  • Paul Coull
    February 14, 2007 at 9:07 pm
    Sounds like a damaged file. Does all the 3 hours of footage open in quicktime?
    Unless anyone else can think of away around it. You may have to capture it again but do a capture now.
    But one thing I do know, timecode break is not a good thing! Check the recorder heads on your camera.
    grafxflow
    grafx that flow!
  • Antonio Aguirre
    February 14, 2007 at 9:14 pm
    Sure will.
    It does play fully in Quicktime. I’ll check the heads of the deck we recorded on, I know they haven’t been cleaned very recently.
    Thank you.
  • Paul Coull
    February 14, 2007 at 9:21 pm
    Going out on a limb on this one, but when you open it in quicktime and check the movie properties option. Is there a video, audio and timecode layer. Try deleting it and see how final cut copes with it.
    Or resave the video file out of quicktime.
    grafxflow
    grafx that flow!
  • Paul Coull
    February 14, 2007 at 9:23 pm
    Oops! delete the timecode layer.
    grafxflow
    grafx that flow!
