[juna suleiman] “What I have are many cards I put in folders according to months and dates so I began converting into a similar work order.”
GOOD! Now those are your archive drives…separate from your media drives. In case you didn’t know that.
[juna suleiman] “Yet, I do not have enough budget to get all those harddesks and back them up”
Yeeesh! Well…gotta figure that out. At least get bare SATA drives and a USB/Firewire drive dock. That’ll make them cheaper.
[juna suleiman] ” I was wondering, if I use the option prores “proxy” and work offline, then work online- include all the clips which were not added and will be by using clipwrap 2- won’t that create a problem later for the online work?”
Yes, it would. It would be a biggish headache. If you color coded those so that you worked with them at full res, and then all the other stuff you could encode as Proxy, or even lower (Offline RT HD) quality…then you could separate them out when it came time to online.
[juna suleiman] ”
also if you know the difference between sizes of prores 422, LT and proxy?”
Proxy is about half the size of LT.
[juna suleiman] “Last but not least, are other programs such as Avid or premier more recommended in my case?”
Yes. Premiere will allow you to work with the files in the native resolution…no offline encoding needed. But I would recommend that you NOT edit from the masters…copy them first to a media drive, so you have a separate media drive and backup drive. But you can work with the smaller, native resolution files.
And yes, Avid has amazing media database capabilities and you can AMA the footage in, encode to DNxHD36, or smaller, and then relink later and transcode to higher res.
Just depends on what NLE you are most comfortable with. But if you lack the budget for hard drives, you will be hard pressed to buy another NLE. Adobe has the Creative Cloud though…you can rent it on a monthly basis.
Shane
Little Frog Post
