Activity Forums Apple Final Cut Pro Problems copying/cutting in/out selection of a single clip
  • Problems copying/cutting in/out selection of a single clip
    Posted by Ryan Hughes on October 31, 2017 at 1:49 pm
    For some reason I’m having a problem copying/cutting an in/out selection of a single clip on the timeline:
    -Generally when it’s an in/out selection of a single clip it does not make the copy. When I paste, it pastes whatever was previously copied.
    -If I try to cut the in/out selection, it performs the cut, but when I paste, it pastes whatever was previously copied (this is the most frustrating problem)
    -I can cut/copy in/out selections of multiple clips and paste the selection without issue. This only seems to happen when it’s an in/out selection of a single video clip on the timeline.
    -If I select the entire single clip and copy it, it pastes fine. The problem only happens with an in/out selection of a single clip.
    Noah Kadner replied 8 years, 10 months ago 2 Members · 4 Replies
