Activity › Forums › Apple Final Cut Pro Legacy › Problems Copy, Pasting from Word to Boris Title 3d
  • Problems Copy, Pasting from Word to Boris Title 3d
    Posted by Mikep on February 24, 2006 at 7:14 pm
    In Final Cut 5.0.4, when I copy text from a word document into Title 3d, sometimes only the last sentence will actually copy over. It seems to be related to when there is a new paragraph in the word document. For example if I copy a 5 line paragraph and paste it into Title 3d everything works fine, I format the text and move on. But when I copy, 2 or 3, 1 line paragraphs, like say a conversation between 2 people, only the last line will paste. I’m wondering if anyone has seen this before and if there is a workaround.
    Mike
    Dean Sensui replied 20 years, 7 months ago 5 Members · 5 Replies
  • Doug Bassett
    February 24, 2006 at 7:50 pm
    Try hitting the left or up arrow a few times to see if it’s hiding.
    Also try pasting the text into a text editor (to strip gremlins), re-copying it and then paste in to FCP.
  • Bryce Whiteside
    February 24, 2006 at 8:37 pm
    I’m sure the document came from another person, but I recommend getting in the habit of using Shift+Return = Insert line break (soft return or line feed in UNIX).
    Hitting Return defines a paragraph break with is a carriage return/line feed.
    Inquiring minds…
    Bryce Whiteside
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Mac OS X 10.4.5 QuickTime Pro 7.0.4
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
    After Effects 6.5
  • Mikep
    February 24, 2006 at 8:53 pm
    Thanks, I pasted into text edit first and that works. Unfortunately I am working from transcriptions from multiple interpreters so a hard return is all I’ll get.
    Using text edit is faster than pasting each line individually and retyping is out of the question.
    Any other work around eliminating the middle step would be much appreciated though.
    Mike
  • Debe
    February 24, 2006 at 9:33 pm
    You could do a find/replace in the text document and replace all the hard returns with a soft return.
    I’m not sure how to do that in Word, but it works in AppleWorks. You likely will have to “show invisibles” and copy one from the document and paste it into the find/replace window. Ditto on the soft return. Type one in somewhere appropriate, and then copy it.
    debe
  • Dean Sensui
    February 24, 2006 at 10:04 pm
    The search/replace method as suggested is probably best.
    Unfortunately there’s a lot of people who use word processors and even email like a typewriter, hitting the “return” key at the end of every line, rather than letting the software do an automatic word wrap.
    Dean Sensui — http://www.HawaiiGoesFishing.com
