Activity › Forums › Apple Final Cut Pro Legacy › Problems Converting to .mp4
  • Problems Converting to .mp4
    Posted by Dave George on November 2, 2011 at 8:29 pm
    Hey fellas, Client asked me to provide a video as .mp4. When I use Compressor to try to convert the .mov to .mp4 it looks terrible. Very pixelated. When I use QuickTime Conversion in FCP it looks worse *and* it won’t let me choose a 16:9 aspect ratio. I’d prefer to use Compressor, anyway, but I’m curious about the FCP issue. In any case, below are the FCP sequence settings and the Compressor settings. Anyone see what I’m doing wrong? I’ve also included the preview window…
    Thanks a million!
    Dave
    FCP Sequence Settings
    Frame Size: 1440 x 1080
    Aspect Ratio: HD (1440×1080) (16:9)
    Pixel Aspect Ratio: HD (1440×1080)
    Compressor Apple ProRes 422
    Audio Settings
    Rate: 48 kHz
    Depth 16-bit
    Config: Channel Grouped
    Compressor Settings
    Description: No description
    File Extension: mp4
    Estimated size: 320.89 KB
    Segmentation on cluster disabled
    Audio Encoder
    Format: MPEG4
    Sample Rate: 44.100kHz
    Channels: 2
    Bits Per Sample: 16
    AAC encoder quality: high
    Data rate: 64 Kbps
    Video Encoder
    Format: MPEG4
    Width: 640
    Height: 360
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: 25
    Frame Controls: Automatically selected: Off
    ISMA Profile: 1
    Constant bit rate: 384 (Kbps)
    Hinted for streaming server with
    packet size: 1450 bytes
    and packet duration: 100 milliseconds
    Enhanced Podcast: Off
    Dave George
    Marketing Director
    Dave George replied 14 years, 11 months ago 2 Members · 2 Replies
  • Roli Rivelino
    November 2, 2011 at 9:38 pm
    I don’t use Mp4 settings much but your estimated file size is tiny and your bit rate is low, can you up the bit rate? Thus giving you an overall bigger file size and thus a better quality video
    https://www.rolirivelino.com/
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
  • Dave George
    November 3, 2011 at 2:09 pm
    Hey, Roli! Thanks for the reply. The tiny file size was because I was just marking a very small In/Out point to test the output, but I shall muck with the bit rate. Thanks again!
    Dave
    Dave George
    Marketing Director
