Activity Forums Apple Final Cut Pro Legacy problems converting files w/ProRes 4444 compression
  • problems converting files w/ProRes 4444 compression
    Posted by Barton Lewis on July 15, 2010 at 7:54 pm
    I have a question which I think is appropriate to this forum, but if not, please direct to me to correct one. I am a filmmaker who had his 16mm films digitally scanned and rendered with ProRes 4444 compression as very large QuickTime files (19 GB). I was told I could convert these files to smaller ones for web use using either Final Cut Pro or QuickTime Pro. I used the Export feature in QuickTime Pro to make a smaller (4,785 KB) file. However, when I open the file in QuickTime, only sound plays, no picture. The settings I used were Export: Movie to QuickTime Movie; Use: Streaming: Medium (I also tried Low); Options, Settings: Compression Type: H.264; Frame Rate: 10 fps; Key Frames: Every 50 frames; Data Rate: Restrict to 80 kbits/sec; Optimized for Streaming; Encoding: Best Quality (Multi-pass); Dimensions: 320X240 QVGA with the Preserve Aspect Ratio box checked (the aspect ratio of the original file is 1920X1080); Deinterlace Source Video box unchecked; PREPARE FOR INTERNET STREAMING box checked; Hinted Streaming; Make Movie Self-Contained box checked. I have not included the audio settings since the sound is working.
    I noticed that when I open the 19 GB file, a large screen appears which I have to change to Half Screen or Fit to Screen; when I open the smaller file, a much smaller QuickTime screen appears which I then enlarge (although it makes no difference – sound but no picture plays in any case). I would greatly appreciate any help anyone can give.
    Barton Lewis replied 16 years, 1 month ago 2 Members · 2 Replies
  • Sascha Engel
    July 15, 2010 at 8:32 pm
    Well, first of all I think, you are missing some plug ins for your QT Player to be able to play the H.264 – you get download those from the web.
    Secondly, if you have FCP, you might also have Compressor, I do recommend to encode the files with compressor – it is much better quality.
    Maybe you can tell me your system spec – computer and what software you have on it.
    Another option is the application “MPEG Streamclip” to convert – you can download that one as well for free from the web.
    Greetings,
    Sascha
  • Barton Lewis
    July 16, 2010 at 7:49 pm
    Thank you. I have QuickTime 7 (not the free version) — and it says “QuickTime [7] features advanced video compression technology called H.264 to deliver brilliant, crisp HD video using less bandwidth and storage.” So are you sure I need to download something to see my files? Second, what is FCP? I am no expert but it would seem that everything I need to convert and play my files is self-contained in QuickTime 7 — but perhaps not. I have a Toshiba Satellite 1550 CDS laptop and I am using Windows XP.
