Activity Forums Adobe After Effects Expressions Problems controlling layers in a precomp with a parent null object.
  • Problems controlling layers in a precomp with a parent null object.
    Posted by Ter Ber on August 21, 2017 at 12:23 pm
    I have several text layers in a pre-comp with these expressions to the scale and opacity.
    Now moving the “cursor” null-layer in the parent composition works correctly. It interacts and controls the opacity and scale of the precomposed text layers (Kursdel-intro), fine ☺
    BUT only if I move the “cursor” layer. I want to move the precomposition and get the same interaction with the “cursor” layer.
    How do I move the precomp, with the null in a fixed position, and get the same effect?
    //scale
    minDist = 5;
    maxDist = 100;
    minScale = 50;
    maxScale = 130;
    C = comp("Kursdel-intro").layer("cursor");
    dist = length(C.toWorld(C.anchorPoint),toWorld(anchorPoint))
    s = ease(dist,minDist,maxDist,maxScale,minScale);
    [s,s]
    //opacity
    dMax = 100;
    dMin = 33;
    d = length(comp("Kursdel-intro").layer("cursor").position,position);
    ease(d,dMin,dMax,100,33);
    Ter Ber replied 9 years ago 2 Members · 4 Replies
  • Scott Mcgee
    August 21, 2017 at 4:15 pm
    C = comp(“Kursdel-intro”).layer(“cursor”);
    and
    d = length(comp(“Kursdel-intro”).layer(“cursor”).position,position);
    This just needs to be relabelled to the name of the Precomp.
    So change this “comp(“Kursdel-intro”).layer(“cursor”)” to “comp(“Kursdel-intro”).layer(“NAME OF PRECOMP“)”
    I’ve just tested it on my machine, so as long as that’s what you want to do. That should connect it to the precomp instead of the NULL Object.
  • Ter Ber
    August 22, 2017 at 12:29 pm
    Should be good enough for me and Scott McGee, but nope ☹
    The pre comp text layers must be connected to the null/cursor in some way, or else I can’t determine where the scale/opacity animation will kick in, right?
    Thanks for helping Scott. I tried your fix, but then nothing happened, but you are probably onto something with the precomp target.
    Here’s a gif (PS in this the comp has changed name to “prealltext”)
    As you can see here I want the precomp “alltext” text layers to animate the same way it does when I move the “cursor” null layer.
    Terje
  • Scott Mcgee
    August 22, 2017 at 9:50 pm
    Won’t lie, haven’t a foggiest. Tried a few things out. As it references the anchorPoint of the Master Comp, it’s just the illusion that if it hovers over it works. It doesn’t it’s basing it off the anchor point of the Null and as long as your precomp compares to the null’s anchor point it works.
    I tried getting the precomped items to reference the null object and rework out the difference, but I think the toWorld is setting it in stone…(I won’t lie don’t know much about toWorld and toComp.) with no success.
    best I can offer, as I hope Dan might look at this and go here’s an answer, but if not try these
    https://motionscript.com/design-guide/proximity.html
    https://motionscript.com/design-guide/collision.html
    The expressions for these are similar in a way the top one uses position over AnchorPoint, which I think might be more down the route you’ll want. The one below is a little more complex, but again it has the similar idea of if something crosses paths it reacts.
    This way might be a better solution, which you can precomp and get it to reference the cursor to the position, so when you move the position of the precomp, it should be able to rework itself out.
    Apologies if the above waffle makes no sense, but in my head I think thats your best option.
  • Ter Ber
    August 24, 2017 at 2:44 pm
    No worries, Scott. I had to give up, animate the null and manually position-keyframe a precomp of the whole shebang. Works for now, but thanks a lot for taking the time, Scott.
    PS I believe Dan was the origin of some of my script expressions. I’m sure there is a solution in his guide somewhere.
