Activity › Forums › Apple Final Cut Pro Legacy › Problems Compositing Animation w/ Alpha and AIC footage
  • Problems Compositing Animation w/ Alpha and AIC footage
    Posted by Derek Rottman on July 18, 2009 at 2:02 am
    Working on a timeline using the AIC codec. After exporting the lower third out of AE with an Animation w/ Alpha codec I get this stutter at the end of the graphic:
    https://www.derekrottman.com/Momentum/graphictest.mov
    It’s almost like it jumps back 2-3 of video when it comes out of the lower third…
    As far as I can figure the framerates are the same…I’m at a loss…I’m becoming less of a fan of the 5D Mark II.
    Any ideas?
    Andrew Kimery replied 17 years, 2 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    July 18, 2009 at 2:06 pm
    Tried exporting from Compressor using the AIC codec? Or Pro Res? MIght fix you right up.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Rafael Amador
    July 19, 2009 at 4:38 pm
    [Derek Rottman] “As far as I can figure the framerates are the same…I’m at a loss…I’m becoming less of a fan of the 5D Mark II.”
    Hi Derek,
    I think that the best way to work with the 5D, is to transcode the clips to Proress (keeping all the setting: Size, pixels aspect, field order) and then conforming the stuff in CinemaTools.
    Rafael
    http://www.nagavideo.com
  • Andrew Kimery
    July 19, 2009 at 9:01 pm
    Almost every time I’ve run into this problem it’s because the clip that ‘jumps’ isn’t completely kosher. If you re-export the source clip same as source and drop that new clip in the timeline I bet it will play fine under the graphic.
    -A
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
