Activity Forums Apple Final Cut Pro Legacy Problems Capturing Material
  • Problems Capturing Material
    Posted by Damir Licina on October 2, 2010 at 10:04 am
    “Capture encountered a problem reading the data on your source tape”
    I’ve searched the forums and found this thread
    https://forums.creativecow.net/readpost/8/994720
    ..but still wasn’t able to figure the problem out. Checked the settings several times and tried different settings as well. I know, for a fact, that the deck and the tape is OK since I downloaded the trial version of AVID and the capture process went fine.
    Trying to capture from a Sony PD 150
    Thanx in advance
    Damir Licina replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
