Activity Forums Adobe Premiere Pro Problems Capturing HDV
  • Problems Capturing HDV
    Posted by Phil Condit on July 10, 2011 at 2:09 am
    I am trying to capture video from my Canon XH A1 via firewire. Normally this works fine. This time the capture window reports that the device is “offline”, but when I go to the control settings it reports that it is “online”. The play and stop buttons work, but I see no video preview in the monitor and the record button is not available. I have turned everything off and on, connected, disconnected and reconnected, tried another firewire cable. At one point the record button was available despite there being no video on the monitor. I tried to record, but when I stopped the recording no box showed up for me to tile the clip and there was no clip recorded in the bin. And, of course, I promised the project to the customer TOMORROW!
    Any suggestions will be greatly appreciated. (Here’s hoping nobody else has a life and is out on a Saturday night)
    -Phil
    Jeff Pulera replied 15 years, 2 months ago 4 Members · 4 Replies
  • Jon Barrie
    July 10, 2011 at 2:52 am
    Be sure to check the capture capture settings are set to HDV. DV setting will still control the camera deck but won’t capture HDV.
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Phil Condit
    July 10, 2011 at 3:34 am
    Thanks for the suggestion. They are set on HDV. I even tried starting another project with the correct settings of 1080 30p to see if maybe I did something wrong the first time, but with the same result.
    -Phil
  • Todd Kopriva
    July 10, 2011 at 3:39 am
    There are some troubleshooting suggestions here:
    https://kb2.adobe.com/cps/828/cpsid_82848.html
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Jeff Pulera
    July 11, 2011 at 2:59 pm
    Hi Phil,
    My understanding is that most (if not all) HDV camcorders that offer 24p or 30p modes actually record that signal in a 1080i wrapper (pulldown is added) so even if you shot in 1080p30 you may need to capture as 1080i60
    Jeff Pulera
    Safe Harbor Computers
