Activity Forums Apple Final Cut Pro Legacy problems capturing HDV with fcp 5.1.4
  • problems capturing HDV with fcp 5.1.4
    Posted by Frixman on March 5, 2007 at 5:12 pm
    hi,
    first of all thanks for your atention.
    i tried to capture with fcp from a tape recorded in hdv 720/25p. however, fcp is not able to capture the entired tape. it make cuts in the capture.
    i put the tape at point and press capture now. the tape runs and the capture starts. when the take changes a window appears saying “searching for media” and generates a new clip but loosing the beginning of the take.
    i hope you can help me.
    thanks
    Frixman replied 19 years, 6 months ago 2 Members · 2 Replies
  • Paul Coull
    March 5, 2007 at 7:26 pm
    Is it a timecode break? or is the drive your capturing to, fast enough.
    grafxflow
  • Frixman
    March 6, 2007 at 10:17 am
    thanks for your fast answer.
    the tape hasn´t timecode break and the discs are able for the edition in fcp. in fact i work with digital betacam to 4:2:2 and the system runs correctly.
    it only happens with HDV 720/25p.
    anybody had the same problem?
    thank you
