Activity Forums Avid Media Composer problems capturing footage on Avid Xpress Pro
  • problems capturing footage on Avid Xpress Pro
    Posted by Taracarey on September 22, 2005 at 5:58 pm
    I hope someone can help! I have just purchased Avid Xpress Pro HD and am trying to do the initial set up so that the Avid will be able to capture footage from my camera. But the problem is that the Avid keeps saying
    Satesh Ramjattan replied 21 years ago 3 Members · 2 Replies
  • Samuel A. martin
    September 23, 2005 at 7:43 pm
    You need to add a deck (probably generic PAL/NTSC device) to the channel you have created. Then go to capture tool and click the box under the playback button and select check decks.
    That should do
    Sam
  • Satesh Ramjattan
    September 24, 2005 at 3:15 pm
    “A friend has suggested its because I need to download a driver for the USB port on my PC computer so that it can read the camera”
    Do you have your camera hooked via USB or firewire?
    If USB, then i don’t think you can choose OHCI in deck config since OHCI is firewire.
    let me know
