Activity › Forums › Apple Final Cut Pro Legacy › problems capturing because of source tape
Posted by Sean O’boyle on June 4, 2007 at 5:00 pmi am using Final Cut Pro HD 4.5 on a Dual 2.5 GHz PowerPC G5 Mac OS X version 10.4.9 with 1 GB of memory. i try to capture video and it stops after a couple seconds with this message.
capture encountered a problem reading the data on your source tape. This could be due to a problem with the tape. Capture has been aborted and your clip has been saved.
please help
Blackdrape replied 19 years, 2 months ago 5 Members · 8 Replies -
Sean O’boyle
June 4, 2007 at 5:23 pmit might help that I’m capturing from a mini-dv tape on a mini dv deck with a firewire cable
Lee Berger
June 4, 2007 at 5:31 pmI’ve run across that problem when there is a bad spot on the tape resulting in a data error that usually cannot be seen as would a drop out. The way I’ve solved the problem is to capture around the bad spot which in my experience is right where the capture fails. I you can afford to loose the material capture right up to the error and then 5 or more seconds after the failure. The other work around is to capture vial analog device such as AJA I/O using the component inputs. I know not everyone has this capability, but it works.
Lee Berger
http://www.leebergermedia.com -
Sean O’boyle
June 4, 2007 at 5:50 pmI’ve tried capturing in the middle and in the beginning of the tape and i got the same message both times.
Lee Berger
June 4, 2007 at 6:20 pmDoes it fail in the same spot each time? If so use device control (mark in and out) to capture before and after the failure.
Lee Berger
Neil Ryan
June 4, 2007 at 10:18 pmWhere did the tape come from?
It may be a difference between your Capture Settings and the actual tape settings; ie frame rate, timecode type, video standard (NTSC/PAL) audio rate (48k v 32k) DVCam v miniDV etc. -
David Bogie
June 5, 2007 at 2:36 pmAnd it might be that your playback deck simply does not like the tape. If you recorded on a Sony and are playing on a Canon, the camcorder’s head patterns may not match closely enough to play coherently.
Use the same deck you shot on. Get a cleaning tape and run it through the deck.
bogiesan
Blackdrape
July 25, 2007 at 3:48 pmHi there.
Did you figure out what the problem was?
I’m having the same problem. Any more suggestions?
