Activity Forums Apple Final Cut Pro Legacy Problems capturing audio and video as one file
  • Problems capturing audio and video as one file
    Posted by Aaron Zeghers on May 21, 2009 at 9:08 pm
    I’m capturing from a Beta tape using Final Cut, which is something I’ve done numerous times before.
    But for some reason, Final Cut has decided to start splitting the video and audio of my capture files, and saving them in separate folders. The audio get put in Audio Capture Scratch, and the video is saving the regular Capture Scratch folder. I need the file as one, mostly just for simplicity’s sake.
    I don’t know what preference or user setting to change to get Final Cut to save the audio and video together as one file in Capture Scratch folder. Possibly I need to delete the user preferences and start fresh, but I don’t know how to do that either.
    Thanks for any help.
    Steven Trauger replied 17 years, 3 months ago 2 Members · 1 Reply
  • Steven Trauger
    May 21, 2009 at 11:23 pm
    Hi Aaron,
    Try this…
    Under “system settings” where you select your primary and secondary scratch disks etc. there is also a small option below that portion of the window where you can capture audio and video separately. Make sure this option is not selected. My best guess is that that’s what’s happening to you here.
