Activity › Forums › Apple Final Cut Pro Legacy › Problems capturing
  • Problems capturing
    Posted by Lur Idoy montero on October 19, 2010 at 4:13 pm
    Hello,
    I am trying to capture the images from a project I am working at. I am using a firewire cable to connect my Panasonic AG dvx100 with my Mac Book Pro. I can actually see the images on FC, and play them properly. But when I start the capture, it only leasts 3 seconds, and after that the capture stops. I do get a clip that can be played. It says it’s a problem with the tape, but I’ve tried with different tapes and on different points of the tapes, and the error message always appears on the third second, stopping the capture.
    I’ve tried cleaning the heads, but I still get the same error. Also, I’ve deselected boxes for “abort capture on dropped frames”, but I never manage to capture further than exactly three seconds.
    Does anybody know what the problem might be? Thank you very much!
    Lur Idoy montero replied 15 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Michael Sacci
    October 19, 2010 at 5:00 pm
    What are your capture settings? Been a long time since I captured a tape but this sounds like a setting mismatch. Use the DV easy setup. Post your capture settings.
  • Lur Idoy montero
    October 19, 2010 at 5:47 pm
    Capture Settings on Final Cut:
    Device Control: FireWire NTSC
    Capture Input: DV Pal 48kHZ
    Is this what you mean? I am sorry, I am quite new with this, so I get a bit lost sometimes.
  • Alex Elkins
    October 19, 2010 at 6:13 pm
  • Lur Idoy montero
    October 19, 2010 at 6:19 pm
    No, into my hard drive. How do I capture it onto a USB drive?
  • Gary Askham
    October 19, 2010 at 7:26 pm
    Your video settings and remote settings don’t match.
    They should either be both PAL or both be NTSC (PAL for UK, NTSC for US).
    FCP and Avid Technical Support
    Air Post Production
    Shoreditch – London
  • Alex Elkins
    October 20, 2010 at 9:39 am
    [Lur Idoy Montero] “How do I capture it onto a USB drive?”
    You shouldn’t, it just sounded from your description like you might have been (USB is not fast enough to capture video and can result in these immediate failures to capture). See Gary’s response below for the solution.
    All the best,
    Alex
    Salad Daze Films – Freshly Tossed
    Check out my latest addition to the Creative Cow Reels Section
  • Lur Idoy montero
    October 22, 2010 at 3:02 pm
    It’s working now. Must have been the settings.
    Thanks everyone!
