Activity Forums VEGAS Pro Problems burning BD-R with DVD Architect, playback is in fast forward?
  • Problems burning BD-R with DVD Architect, playback is in fast forward?
    Posted by Richard Uruchurtu on February 1, 2012 at 12:01 am
    Hello all,
    I am trying burn a blu-ray disc out of DVD Architect Studio 5.0.
    I’m using a .TS stream from arcsoft Show Biz Capture. The TS stream is AVCHD. For whatever reason the audio will not load into Architect. So I demuxed the audio with DGIndex to aac (native format). Then I added that as the audio track in DVDa.
    Anyways!
    The burn is successful and does not require a video re-encode(the audio does re-encode to ac3). When I tested the Blu-ray on my PS3… The video is in fast-forward and the audio is playing at normal speed (which goes way out of sync of course though).
    I’m not even really sure where to start on this problem… My challenge is that I need to be able to burn a blu-ray disc without a video re-encode. Where is the issue most likely originating? The capture? The audio demux? The burn?
    Thanks in advance.
    Richard Uruchurtu replied 14 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
