Activity Forums Avid Media Composer PROBLEMS batch importing HDV
  • PROBLEMS batch importing HDV
    Posted by Annu Lilja on September 2, 2009 at 2:12 pm
    Hi! I am batch importing HDV material, and all too often the capture ends with a “try again” message. My settings should be correct so that the deck would ignore timecode breaks, but I am still having huge problems. Any suggestions?
    Thank you so much!
    Annu
    Kris Anderson replied 16 years, 12 months ago 2 Members · 1 Reply
  • Kris Anderson
    September 3, 2009 at 11:34 am
    If there are timecode breaks on the tape then Avid may be having difficulty re-cueing. Try lowering the deck pre-roll time until it is able to find sufficient control track to continue.
