Activity Forums Adobe After Effects Problems Animating Logo using a Track Matte
  • Problems Animating Logo using a Track Matte
    Posted by Nathan Karamanski on June 1, 2012 at 2:47 am
    Hi, long time reader, first time poster.
    Im currently having trouble creating a simple track matte animation. Basically, my goal is to create a multi-colored logo that zips upward from inside of a track matte. I am not sure if this is the technique that i need to use for this situation, but every time I create a shape layer and track matte it to a single color text layer, it works just fine. As long as the layer I am luma track matte-ing is a single color I am not running into any issues. It’s when I try and use that same concept on a multicolored logo i run into issues. Once i select the luma/alpha track matte option on my shape layer and connect it to the multi-colored layer above it I cant seem to figure out a way to keep the logo’s original color scheme intact. The logo will take on the color property of the single fill color of the Shape layer I am using to Alpha/luma track matte. I’ve tried using null objects/adjustment layers. Ive also tried making the opacity of the shape layer 0%. All that does is make anything track matte-ed invisible. All i want to do is create a simple square track matte that i can put around a logo and animate the logo upwards or downwards into the track matte without transforming the multi-colored logo into a single color logo. Can anyone help?
    Nathan Karamanski replied 14 years, 2 months ago 2 Members · 2 Replies
  • Dan Fredley
    June 1, 2012 at 8:32 pm
    • The logo needs to be below the square shape layer in the timeline window.
    • Make sure both layers are visible at this point.
    • In the comp window make sure the top of the square shape layer is at the top of the logo.
    • Animate the logo so that it comes above the square shape.
    • Make sure the square shape layer is set to 100% opacity.
    • Then on the logo layer in the timeline set the track matte to “alpha inverted matte.”
    • The square shape layer’s visibility switch should be turned off automatically when you set the track matte
    • Then as you scrub through your timeline the logo should appear as it rises above the shape layer.
    Dan Fredley
  • Nathan Karamanski
    July 1, 2012 at 7:57 pm
    Ahhh. Thank you! I knew it was going to extremely simple. The C.C. community is the best!
