Activity Forums Apple Final Cut Pro Legacy Problems anamorphic FCP5 + anamorphic
  • Problems anamorphic FCP5 + anamorphic
    Posted by Carlos Lopez on June 24, 2005 at 11:25 am
    Hello, I have a problem capturing anamorphic footage. SDI + Decklink Extreme + 10.4.1 + FCP5. All the settings capture and sequence are tagged to Anamorphic. But when i captured and open item properties doesn’t appear that it’s anamorhpic. And i have to do manually before drag to the timeline. Does exist any solution for it ??. Please i don’t want to tag every clip to anamorphic, with FCP 4.5 doesn’t happen. What i have to do ??
    Thank You
    Rob Tinworth replied 21 years, 3 months ago 3 Members · 2 Replies
  • Walter Biscardi
    June 24, 2005 at 11:33 am
    Have you posted this in the BlackMagic / Decklink forum? I sounds like it’s a Capture Setting issue, but I’m sure the BlackMagic guys will help you figure it out.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Rob Tinworth
    June 25, 2005 at 4:09 am
    I think the anamorphic setting is bit hit and miss – I’ll get some files that get tagged properly and some that don’t. It doesn’t actually make any difference to the media file, so it’s not a big deal.
    In your logging bin, open up the column ‘anamorphic’ (scroll across to it, or better still creata custom logging setting with ins, outs durs, tape names & anamorhphic). Then you can select all of your clips at once and click them to anamorphic with one click.
    Rob Tinworth
    http://www.1021.tv
