Activity Forums DVD Authoring problems
  • problems
    Posted by Kerry Grayson on June 6, 2006 at 3:44 pm
    hi i managed to convert an avi video file using a trial version of Gear Video 8.1 and have now burnt it onto dvd+rw. it plays well on a PC and also a Mac. however it won’t play properly on the dvd player thats with the TV.- it stutters and stops and starts. i need it to play on all three. please help.
    Mike Smith replied 20 years, 2 months ago 3 Members · 2 Replies
  • Noah Kadner
    June 6, 2006 at 4:08 pm
    Is gear an authoring program or just video conversion? To make a DVD player compatible disc you need to author. For the PC- Adobe Encore or Sonic DVDit would do the trick.
    Noah
  • Mike Smith
    June 8, 2006 at 11:35 am
    Gear Video will allow for DVD authoring, Mpeg 2 encoding – what’s needed to make a DVD
    Stuttering playback on a DVD player suggests maybe the data rate of your mpeg2 video is too high – did you keep it down below 8Mb/sec? If you left the sound in PCM format, that can eat data rate …
    https://www.gearsoftware.com/support/documentation/encode-video-dvd.cfm might help.
