Activity › Forums › Adobe After Effects Expressions › Probleme whit yousing the ‘seedRandom’
  • Probleme whit yousing the ‘seedRandom’
    Posted by Taha Boukhari on July 16, 2013 at 2:22 am
    hi
    i have a probleme a bout controling one position in layer whit 2d dimensions.I use the seedRandom like expression but it dosent work when i applied in one dimension but when i use random it work.
    this is some capture from my screen
    dosent work whit seedRandom
    work whit random
    Jeff Kay replied 13 years, 2 months ago 3 Members · 2 Replies
  • Dan Ebberts
    July 16, 2013 at 4:01 am
    You can’t use seedRandom() that way. I think this might be what you’re trying to do:
    temp = transform.position[0];
    seedRandom(2,true);
    [temp,random(200,1000)]
    Dan
  • Jeff Kay
    July 17, 2013 at 3:31 pm
    To elaborate seedRandom() does not generate random numbers itself. It sets the seed value used by random() or any other effects that generate random numbers.
