Activity Forums Avid Media Composer Problem with Xpress Pro 5.2 – No real-time playback
  • Problem with Xpress Pro 5.2 – No real-time playback
    Posted by Bimdas on March 19, 2006 at 12:39 pm
    I’m currently learning the Avid interface and am getting the hang of the modes but on my AMD 64 3000+, when I try and play the footage, the time bar moves but the video doesn’t play and neither does the audio.
    I can scrub through the footage and it plays in the record monitor in real-time but when I try and play it, it doesn’t seem to work.
    I had previously practised with Xpress on a slower Pentium 4 with no problems but I’ve read around and have noticed alot of people have no troubles with AMD, I’m wondering if its some sort of driver or preference setting?
    thanks
    Joe Valenti replied 20 years, 4 months ago 4 Members · 4 Replies
  • Chaz Shukat
    March 19, 2006 at 8:24 pm
    [Bimdas] “when I try and play the footage, the time bar moves but the video doesn’t play and neither does the audio.
    I can scrub through the footage and it plays in the record monitor in real-time but when I try and play it, it doesn’t seem to work.”
    If I’m understanding you correctly, you can scrub through the video in the source monitor but it won’t play. Plays OK in the records monitor and I’ll bet it would play in a pop up monitor if you tried. This leads me to believe that the problem is simply that you have a bin open that is touching or intruding in the source monitor window, which will prevent playback. Try checking that first and just move that bin off the source monitor, should play then. If not, it may be a driver issue, but it seems to me that if it were a driver issue, it wouldn’t play in any monitor.
    Hope that helps.
    Chaz S.
  • Joe Valenti
    May 21, 2006 at 6:31 pm
    I am having the same problem with my AVID Xpress Pro HD. I can scrub through the source and record monitors but when i try to play them out, the image freezes until I pause it and then it freezes on the frame I paused on. However, the dv firewire feed going into my panasonic dvx camera plays the timeline just fine. then just recently, it won;t play out at all and I keep getting exception fatatl error messages over and over until the prgram crashes. The system I am running is a dual 3.4gh, 2 gigs ram, graphics card nvidia geforce 6800 gs, sli. It’s a great computer, not sure if it’s a setting or something. Any thoughts?
  • Jon Zanone
    May 22, 2006 at 5:27 am
    It would really help if you gave some specific details regarding your setup, like current OS, what version AXPro, QT version…
    Did you get your system from a reseller, or put it together yourself?
    Jon
  • Joe Valenti
    May 23, 2006 at 2:36 am
    Hi Thanks for the response,
    I’m running windows xp pro, latest quictime that can be dowloaded from the website, someone built the computer for me…. bought it form a seller…. all programs such as maya and 3dmax work perfectly on it…. just the avid is giving me problems… any thoughts?
