Activity › Forums › Apple Final Cut Pro Legacy › Problem with XML Import
  • Problem with XML Import
    Posted by Max Frank on June 5, 2011 at 10:06 am
    I’m trying to import an FCP XML file. It says ‘Importing XML Data’, gets to 78% then just stops.
    I’ve tried trashing the prefs and rebooting. No change.
    I’ve tried breaking the project into 2 x 30 segments. No change.
    Any other suggestions?
    Wayne
    Latest FCP & & OS X – Mac Pro 8GB RAM
    Max Frank replied 15 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Andy Mees
    June 5, 2011 at 10:51 am
    Some questions:
    1) So you have the original project i.e. you are creating the XML file yourself?
    2) And you have no trouble exporting the XML … just having trouble when importing it (on the same machine)?
    3) And if you break the original project into 2 x 30 minute parts and export each as an XML, then BOTH parts fail on import at exactly 78%?
  • Max Frank
    June 6, 2011 at 2:02 am
    Hi Andy,
    Thanks for taking the time to reply.
    Some replies to your questions:
    Some questions:
    >>Yes, I did the export myself.
    >>Correct
    >>Correct
    Hope that helps.
    wayne
  • Andreas Kiel
    June 6, 2011 at 9:55 am
    Some maybe stupid question. Why do you export/import XML on the same machine?
    Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Andy Mees
    June 6, 2011 at 10:29 am
    Hi Wayne
    Andreas raises a good point. I didn’t ask myself as am assuming you must have some kind of reason … but I’d still like to know 😉
    Either way, there is obviously something amiss here. Question: Does this issue only happen with this specific project/sequence XML export or does it happen with any and every project and sequence XML export? e.g. If you create a new project, populate it with a few test clips, and then roundtrip through XML, do it all proceed as it should?
    Cheers
    Andy
  • Max Frank
    June 6, 2011 at 11:52 am
    Why do I XML myself? Great question.
    I wish I had a more exciting answer, but the fact is, I had an errant plug-in that I needed to get rid of.
    I tried using Edit Mule Filter Remover, and FCP hang on the XML import – then I got advice on how to remove the plugin manually via the XML text reader here: https://forums.creativecow.net/readpost/8/1134135
    But again, it didn’t import properly [as per original post].
    Subsequent to my writing I’ve gone through the project clip by clip and removed all instances of the plugin by hand, so I’m back on track – but I am a bit worried that the XML function didn’t work properly,
    I haven’t had a chance to try it on another project yet.
    Thanks again for the concern and input.
    Wayne
  • Andreas Kiel
    June 6, 2011 at 12:38 pm
    Wayne,
    Glad to hear your back on track — you should have told us the reason why you wanted to “XML yourself” (great expression btw :))
    Beside the Edit Mule app and Boukes setup you may try
    https://www.spherico.com/filmtools/removeFilter/removeFilter.zip
    I never did set up any website for it but quite a lot of people do use it. Up to now it never failed.
    So you may try (it’s free) and let me know whether it works.
    Andreas
    Spherico
  • Max Frank
    June 6, 2011 at 12:41 pm
    Andreas,
    Thanks so much for the plugin remover – much appreciated.
    I’ll check it out.
    All the best,
    Wayne
