Activity Forums VEGAS Pro Problem with WAV file on Vegas timeline
  • Problem with WAV file on Vegas timeline
    Posted by Max Schlickenmeyer on June 2, 2012 at 9:55 pm
    I recorded a 48kHz/24bit Stereo WAV file on my Zoom mic. It sounds wonderful when I play it back on the mic, in itunes, etc. But, when I drag it to my Vegas Pro 10e (32 and 64bit) timeline it looks like this
    When I press play it peaks, skips, speeds up, and stops. I get the same thing when previewing the WAV from project media. Any ideas of how to prevent this from importing in such a messed up way?
    On another note I’d like to give everyone involved with the Creative Cow Sony Vegas forum (especially Cow Leaders) a gigantic thank you. You guys are extremely helpful, nice, patient, and knowledgeable. 1000x thank you
    Paul Wright replied 11 years, 6 months ago 6 Members · 11 Replies
  • 11 Replies
  • Steve Rhoden
    June 2, 2012 at 10:26 pm
    Try setting the audio settings/specifications in Vegas to match that
    particular audio you are having a problem with, then import it
    on the timeline and lets know if it behaves the same way.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • John Rofrano
    June 3, 2012 at 1:17 pm
    Yea, I agree with Steve, does your audio card support 48K/24-bit? If not, it could be that Vegas is needing to convert your audio to 48K/16-bit or 44K/16-bit on the fly and that’s causing the stuttering. What is your project audio set to? What is your audio card capable of?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Max Schlickenmeyer
    June 3, 2012 at 4:16 pm
    Thanks for the replies guys, I have a THX TruStudio PC Soundcard w/ Realtek HD Audio which does support 48K/24-bit. I tried matching the audio settings/specifications in Vegas Pro 10 to no avail. I imported it into Vegas 7 with no issues whatsoever. Why it won’t work in 10 is still a mystery.
  • Steve Rhoden
    June 4, 2012 at 9:19 pm
    Got your audio sounding right as yet?
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
    June 5, 2012 at 3:58 am
    Thanks for the follow up Steve! yes! I got the audio working. I rendered the WAV as AIFF in Vegas 7 then imported the AIFF into Vegas 10 (to utilize the multicamera tool) and it came out perfect. I’m assuming that AIFF was the best choice for preserving quality since it’s uncompressed like a WAV file, am I correct in this line of thinking?
  • Steve Rhoden
    June 5, 2012 at 4:46 am
    Yes, AIFF files are uncompressed and comparable to the
    Wave audio format. They were first initially designed for Macs.
    Anyway, glad you found a work-a-round.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Björn Paulsson
    November 25, 2012 at 4:43 pm
    Hello,
    I have the exact same problem:
    .wav worked perfect in sony vegas 9, but total fail in Sony Movie Studio as described above.
    It’s the same computer, so it must be the software. All other things are the same.
    Workarounds are fine, but how about a real solution? Anyone got any ideas?
  • Leif Knudsen
    September 12, 2013 at 11:20 am
    I record sound on a Zoom H4N in .wav 48Khz 24bit.
    I experience the exact same audio problem placing a file on the timeline using Vegas Pro 64bit build 714 for Win7.
    I also would be very happy to know about a fix, not a workaround (I will go try the AIF conversion to “survive”), as conversions are a hazzle, especially when the source is a standard ubiquitous format.
    Best regards
    Leif Knudsen
  • John Rofrano
    September 14, 2013 at 11:17 am
    [Leif Knudsen] “I also would be very happy to know about a fix, not a workaround (I will go try the AIF conversion to “survive”), as conversions are a hazzle, especially when the source is a standard ubiquitous format.”
    You might want to report this problem to Sony. It’s either a problem with the way the Zoom is writing the files or it’s a bug in Vegas Pro. Since it seems to work with earlier versions of Vegas it may actually be a bug. If no one reports it… it will never get fixed which is why I suggest you contact Sony about it.
    ~jr
  • Leif Knudsen
    September 14, 2013 at 11:51 am
    Hi John.
    I will do that … although my experience with Sony Vegas support is disappointing. I reported rendering crashes last year, a well known general problem for Vegas, with no reponse. But I’ll give it a go.
    Regards
    Leif
