Activity › Forums › Adobe Premiere Pro › Problem with WAV audio in Premiere Pro
  • Problem with WAV audio in Premiere Pro
    Posted by Malika on August 21, 2006 at 3:21 pm
    I have imported a WAV file (a soundtrack I made in Audition 2) into Premiere Pro.
    The track will not play continuously in either the source or program monitor for more than a few seconds then it stops interupting the sequence and I have to activate the play button again to continue. Totally unworkable!
    Any suggestions?
    Many thanks
    Malika
    Malika replied 20 years, 1 month ago 3 Members · 4 Replies
  • Mike Velte
    August 22, 2006 at 11:27 am
    Is the bit depth 32 or 16? Should be 16.
  • Ervin Farkas
    August 22, 2006 at 2:34 pm
    It shouldn’t matter as Premiere will conform any file at the time of import. I just worked with a wav file I originally recorded as a CD project at 32 bits.
    Ervin
  • Malika
    August 23, 2006 at 4:58 pm
    Thanks so much for the response greatly appreciated!
    Yes audio is 16 bit – though have since played around with other possibilities – nothing is playing continuously now.Have used Mp3, AVi files etc. Have changed location of source files so beleive this has ruled out possiblity of communication problems with program and ext. HDs. Have re-insalled program and also installed different copy – no use. So think it may be problem with my computer/system.
    Will investigate new virus and spyware. Fingers crossed.
    Many thanks
    Malika
  • Malika
    August 23, 2006 at 8:15 pm
    Sorry maybe rookies shouldnt be so vocal! After installing a better spy ware and anti virus no more problems with playback in Premiere.
    Thanks a lot for feedback and to know we are not alone -sure I will be quizzing you guys in the future.
    Many thanks
    Malika
