Activity › Forums › Maxon Cinema 4D › Problem with v13 C4D studio – selection tool stuck & idle
  • Problem with v13 C4D studio – selection tool stuck & idle
    Posted by Liz Black on August 26, 2016 at 8:49 pm
    Hey there – I’ve been having this bizarre problem where I seem to be stuck on the select tool however it doesn’t even select things as it should – please watch the movie it will make more sense! As you will see at the end of the clip I try to use the render region selector & it turns into a cross hair but does nothing other than move the camera.
    https://youtu.be/YEGU3kaspoY
    Thanks to all suggestions, I have no idea what has gone wrong here.
    Please help a newbie!
    Brian Jones replied 10 years, 1 month ago 3 Members · 3 Replies
  • Jim Scott
    August 27, 2016 at 12:04 am
    In R17 there is an Align Workplane command which will result in the behavior you see with the move tool, but it wouldn’t cause your other issues. Since that command is not available in R13, I don’t know what the culprit is. I assume you have tried quitting and restarting C4D? If not, that and restarting your computer would be a place to start.
  • Liz Black
    August 27, 2016 at 8:22 am
    Yes thanks I have restarted many times 🙁
  • Brian Jones
    August 27, 2016 at 2:11 pm
    even with the X, Y and Z locks on (which it is at first) you should be able to override by directly grabbing the axis handle – which you do – …..
    The behaviour you are getting looks most like having the ‘1’ key pressed all the time (the Move Camera Hotkey by default).
