Activity Forums Apple Final Cut Pro Legacy Problem with Twixtor
  • Problem with Twixtor
    Posted by Isaac David quesada on November 7, 2012 at 7:18 pm
    Hello editors
    I have a video in 60fps, i want to convert it to 4000 fps, so I am using twixtor. If I change the Speed to 33% it works fine, looks good, but what I really want to do is change the Frame Number so I can control the exact amount of frames in that video. When I select Frame Number I only see a frozen image, no matter if I set it on 4000, 60, 30 or 0. Am I doing something wrong? Any help would be gargantually apreciated.
    Isaac David quesada replied 13 years, 10 months ago 1 Member · 1 Reply
  • Isaac David quesada
    November 7, 2012 at 7:46 pm
    Ok, I realized how the frame number works, kind of. I set two keyframes and it did moved, but that`s not what I`m looking for, anybody now how can I make it 4000 fps?
