Activity › Forums › Apple Final Cut Pro › Problem with transitions and still images in FCPX
  • Problem with transitions and still images in FCPX
    Posted by Nicole Robicheau on March 22, 2012 at 7:19 pm
    I’m having a problem using transitions between still images in FCPX. I am using an audio track underneath a series of still images. Whenever I try to drag a transition to the space in between two still photos, it doesn’t work. Instead, the transition is placed at the beginning and the end of the audio track underneath the photos. Is it because the audio track has somehow become attached to the photos? Does anyone have any suggestions on what to do?
    Nicole
    Nicole Robicheau replied 14 years, 6 months ago 2 Members · 2 Replies
  • Mark Morache
    March 23, 2012 at 1:14 am
    Are your photos on the primary storyline? Is there any space between them?
    I’ve encountered a bug where I can’t seem to drag a transition onto an edit. It will apply the transition to the edit BEFORE the one I’m dragging to.
    Sometimes I can get satisfaction by dragging the transition to the edit FOLLOWING the one I actually want the transition. Sometimes I can drag the transition to the clip itself, thereby adding the transition to both edits on either end of the clip.
    If your photos are not on the primary storyline, move your audio out of the primary storyline and then place your stills in the primary.
    Don’t live your life in a secondary storyline.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
  • Nicole Robicheau
    March 28, 2012 at 8:29 am
    Hi Mark,
    Thanks so much for your response. In fact, rather than have my photos on the primary storyline, I had my audio there, which I guess is why the transitions weren’t working. I moved everything around and now it works perfectly.
    Thanks again for your help!
    Nicole
