Activity › Forums › Avid Media Composer › Problem with Timecode display
Michael Phillips replied 12 years, 6 months ago 5 Members · 13 Replies
Michael Phillips
March 28, 2014 at 11:24 pmIt’s not a glitch – NTSC is a 30 frame counting system, so 24 frame native essence will still have as though it’s counting in a 30 frame world, thus the dropping of frames. But all that is keyed off the cadence relationship A, B, C, and D (and a hidden X). If you want to see 24 straight up, then duplicate the START into the TC24 and that will count as :00 to :23.
In an HD project, 24fps is a SMPTE standard, and will count as such in the START column. The START column always counts as the project type.
Michael
Ricky Sanchez
March 28, 2014 at 11:41 pmYeah I get that. Im just saying, to avoid the skipping of frames in the master timecode of your sequence you need to create the sequence while in 1080p/23.976 format.
Michael Phillips
March 28, 2014 at 11:49 pmAh yes. Consistency is key to keep things the same with no surprises.
Michael
