Activity Forums Maxon Cinema 4D Problem with the reflection pass and After Effects
  • Problem with the reflection pass and After Effects
    Posted by Nicolas Plaire on July 5, 2008 at 5:37 am
    Hi everyone… I got a question about compositinh with After Effects…
    Here, I create a sequence in Cinema 4D, but I want to comp it in After Effects rather than using the compositing abilities of Cinema 4D (for further post-treatment)…
    Si I’m using the Compositing Tag, the multi-pass render, with the Object Buffer, the Shadow Pass and the Reflection.
    I have two reflections on the scene. One on the floor that cause me no trouble… I blur it in AE and that’s done. But I have a mirror two and in the comp created for AE, all the reflection passes are with an Add Transfer Mode… So it’s kind of semi-transparent, which is not working for a mirror reflection. I managed to use the Set Matte and played a little with the Alpha Levels in AE, but if the object reflected is black, then I won’t see anything at all in the reflection pass.
    So I was wondering how to create a reflection with an alpha channel maybe, or how to render only the reflection and not the object that reflects, or anything like that…
    Thank you.
    Nicolas Plaire replied 18 years, 2 months ago 2 Members · 2 Replies
  • Hunter Christy
    July 11, 2008 at 1:09 am
    i have no idea if this would work, but its worth a shot.
    BUT. if you put a compositing tag on everything but the mirror. (and uncheck everything but seen by reflections). THEN you add the diffuse layer to the multipass, and render it to a new name.
    import that to after effects, then using the diffuse (transfer mode>stencil alpha) ON TOP of the reflection layer (which is now set to transfer mode>normal), it should cut it out nicely. then just drop THAT comp into the previous, and voila!
    THE BiG HONKIN’
    “The Defenders Of Stan”-lots of after effects
  • Nicolas Plaire
    July 12, 2008 at 5:05 am
    Thanks… I’ll look into it
