Activity Forums Adobe Premiere Pro Problem with the Interface Premiere Pro 1.5 HEELP
  • Problem with the Interface Premiere Pro 1.5 HEELP
    Posted by Julio Crespo on January 26, 2007 at 1:51 am
    I have PP 1.5 and recently when I right click anything and then left click out of the pop up menu the interface desappear. YES… all interface gone. The only pieces of interface remain visible is History, Info and the tools panel. The program dont show any error message and let me to save and open projects, but the interface not appear again until I close and re-open it. I try to Unistall and reinstall but nothing.
    HEEELPPP!!! pleasee
    Aanarav Sareen replied 19 years, 8 months ago 3 Members · 5 Replies
  • Blast1
    January 26, 2007 at 2:21 am
    Problems can be caused by a damaged PluginCache file, You can redo it by holding down the Shift key then starting Ppro and releasing it when the Create, select Project screen appears, re-check Preferences that you have personalized
  • Aanarav Sareen
    January 26, 2007 at 2:31 am
    Did you make any hardware changes? More specifically, did you add/install/remove any software related to your video card?
    – Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Julio Crespo
    January 26, 2007 at 3:05 am
    Not specically, but recently my nVidia Video Card was dead, I remove it and install the motherboard Card again. But this happen a few month ago and the problem appear just a few day. I was double check all video stuff again… You never know
  • Julio Crespo
    January 26, 2007 at 4:31 am
    Nope everything fine on the video stuff. Another problem, I try to install the 1.5.1 Update and diaply a error message “unable to update ASLFoundation.dll The file on your system does not match the orginal PPro file expected and it can not be updated” Whats wrong with this file?? What is this file?. Any advise was apreciated
    Thanks in advance
  • Aanarav Sareen
    January 26, 2007 at 9:19 pm
    Something seems to be corrupted. My recommendation at this point would be to reinstall the entire OS and apps.
    – Aanarav
    Aanarav Sareen
