Activity Forums Adobe Encore DVD Problem with the black spot between menus and transition between them
  • Problem with the black spot between menus and transition between them
    Posted by Miikka Niemi on October 30, 2005 at 1:56 am
    Sorry about posting this directly but I’m in a hurry with my problem. It checked other posts but I think this is the fastest way to get response.
    Okay I’m trying to do menu with large photoshop file. I have split it to the menu sections and done transition videos from the movement between the menus. When I try to put a menu then it’s end action to the transition there’s a black spot between menu and transition.
    I should get menu without that because it looks awful with that. I know that the black spot is problem from dvd format itself but I believe there’s a way to solve this problem.
    I got an advice to do it with only menus. Menu 1 would be the menu that starts the whole thing. Menu 2 would be a motion menu with transition. Menu 3 would be the menu that the transition ends.
    I put the end actions and loop points and everything. Then I tried to preview put encore said unknown error and some numbers.
    Does anybody know what could be wrong?
    I pretty new for using this program but I’m in a awkward situation because I have to do this menu ready in couple of days.
    Every help possible is greeted.
    Nomar25 replied 20 years, 10 months ago 3 Members · 2 Replies
  • D.fokker
    November 1, 2005 at 10:59 am
    this ‘problem’ should only be in preview mode in encore.
    Burn a dvd-rw and check in a standalone dvd.
    The black flashes shoudn’t be there.
    Succes. D Fokker
  • Nomar25
    November 9, 2005 at 1:17 am
    You should check if you made sure that the opening menu is “Set as First Play” and then try previewing it.
