Activity Forums Apple Final Cut Pro Legacy Problem with the Audio Controls
  • Problem with the Audio Controls
    Posted by Samahcinema on August 9, 2007 at 5:09 am
    For some reason, the Audio Controls on the left side the timeline in FCP 6 is not working properly. When I click mute, sometimes it does not work, and whena I solo a track or tracks, it also sometimes does not work.
    does anybody know why this might be happening and how I might be able to get it to work properly again?
    thanks.
    Shian Storm replied 17 years, 6 months ago 2 Members · 1 Reply
  • Shian Storm
    February 7, 2009 at 3:29 am
    I had the same problem and it drove me mad trying to figure out how to fix it. Thought I’d save everyone else the headache.
    I searched the net for this problem, and had decided that Mute and Solo don’t work in Final Cut – well, actually, they work fine, unless you don’t know how Final Cut processes audio.
    Mute and solo won’t work if you have ANY RENDERED AUDIO in your timeline. What you hear is not coming from the tracks themselves but from the Audio Render files.
    Tips to fix.
    In render manager delete all your audio preview files.
    Try disabling audio on as many tracks as you need to get the active number of tracks down to 5 (depends on your system, some systems can handle less, some more, but on the average…most systems are limited to 5-7).
    Try temporarily disabling any foreign format audio (audio that needs to be rendered in order to playback in that specific sequence with those settings)
    Try exporting any such audio that needs to be rendered out to an aif file with the same sample rate and timebase settings as your sequence. Then re-import it, and replace the troublesome audio with the aif.
    That should fix your problem
