Activity Forums Apple Final Cut Pro Legacy Problem with the aspect ratio
  • Problem with the aspect ratio
    Posted by Sala Sultan on May 11, 2011 at 1:51 am
    Hello!
    I export the file from Final Cut Pro in 720 x 576 DV PAL format and I have been told that the aspect ratio is 1.0 when it should be 1.067.
    I’ve tried changing the sequence settings but there is no option to change to 1.067. How can I do this?
    Thanks in advance!
    Sala
    Sala Sultan replied 15 years, 4 months ago 2 Members · 2 Replies
  • Chris Tompkins
    May 11, 2011 at 10:52 am
    Your sequence should be the DVPAL preset for one thing. Let FCP do this for you.
    When you export, Export using “Current Settings” this uses what you have in the sequence for all settings.
    Take the exported file into your fav compression software and create your deliverable.
    Chris Tompkins
    Video Atlanta LLC
  • Sala Sultan
    May 12, 2011 at 1:58 pm
    Thanks! That helped alot
    Best wishes to you guys!
    Sala
