Activity › Forums › Adobe After Effects › Problem with the Animation Codec?
  • Problem with the Animation Codec?
    Posted by Zeke Meginsky on July 7, 2011 at 4:15 pm
    A lot of people say to use the Animation Codec. It’s a default setting in AE. It must be for a reason?
    I was reading that it’s “8 Bit”. Does that mean a lot of color gets lost in digital photographs? Should another codec be used for something with a lot of color? Or am I misunderstanding something?
    Todd Kopriva replied 15 years, 2 months ago 3 Members · 4 Replies
  • Greg Burrus
    July 7, 2011 at 6:34 pm
    From my experience the idea a behind the animation codec is that it is a lossless format thus you loose almost no quality when you render. The down side is it renders out large files and typical does not play well in media players on computers, especially at HD. I’m not sure about the color aspect of it since other formats do display more colors, though it does let you use alpha channels which is one of the reasons I always used it.
    I have used it when rendering broadcast graphics that are to be used in final cut that later on will be render to another format or tape. Though if your going to put your work directly online then animation wouldn’t be the best codec to use.
    I found this forum post here that talks about it a bit https://forums.creativecow.net/thread/2/961973
    and wiki…
    https://en.wikipedia.org/wiki/Animation_codec
    hope this helps
    Greg
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
  • Todd Kopriva
    July 7, 2011 at 11:16 pm
    Because it loses no image information when encoding from an 8-bpc source.
    See these FAQ entries for information about export settings:
    “What is the best format for rendering and exporting from After Effects?”
    “Why is my output file huge, and why doesn’t it play back smoothly…?”
    The second of these covers the downsides of using a lossless codec like Animation.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Zeke Meginsky
    July 8, 2011 at 3:16 am
    Okay. A follow up question. Is there any reason why I should export footage interlaced or to lower or upper field? I’m confused by fields and why I would export interlaced.. would interlaced be smoother? As far as fields, I don’t know which field to use or if I should use one at all. I have things with upper and lower fields in my FCP project (some footage was taken from DVDs that originally had upper fields, and some from DV tapes that obviously use lower). Will that an issue?
  • Todd Kopriva
    July 8, 2011 at 7:16 pm
    Only export interlaced files if your intended playback device uses interlacing. Determine what the specifications of the playback device are.
    Here’s a video that I made to introduce video fields and interlacing.
    Read this page and follow the links on it to learn about fields and interlacing in After Effects.
