Activity › Forums › Adobe After Effects › Problem with Text Motion/Kinetic Typography.
  • Problem with Text Motion/Kinetic Typography.
    Posted by Henry Cox on July 18, 2014 at 7:02 pm
    I’m fairly new to after effects but i’m trying to animate some text that’s being put on top of a video. See 0:26 the word ‘spinning’ as an example of what i’m trying to achieve. https://youtu.be/Pn-6eOxnEMI?t=22s
    Basically I want the word to enlarge/go out of focus like it’s getting too close to the screen, then quickly go back to the normal size. I’ve been using the sure target plugin/watching lots of tutorials but no luck thus far.
    Stephen Smith replied 12 years, 2 months ago 2 Members · 3 Replies
  • Stephen Smith
    July 18, 2014 at 9:33 pm
    To do it I would animate the text’s scale to say: 1st frame = 5% scale, 10th frame scale = 120%, 15th frame = 100%. Make the middle and last frame an easy ease. Add a lens blur or Gaussian blur. Have the blur set to 0 at say frame 12. Then crank it up to around 10 for frame 16. Then back to 0 a few frames later. Hope this helps and best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Henry Cox
    July 18, 2014 at 10:54 pm
    Thanks Stephen
    Think your suggestion has worked quite well!
  • Stephen Smith
    July 21, 2014 at 2:26 pm
    Cool, that is great to hear. Best of luck.
    Stephen Smith
