Activity Forums Apple Final Cut Pro Legacy problem with strobe image in FCP
  • problem with strobe image in FCP
    Posted by Ian Pons jewell on June 25, 2009 at 10:30 am
    I am currently editing with footage that uses strobe lighting on the subject. At times, I cannot view the strobe image as it can’t seem to handle displaying one frame of picture, as this is the amount of time that the strobe lights for. I tried to export as Quicktime, and when viewing the clip outside of final cut, it is fine, but when re-importing the exported clip, it gave the same error. But, when exporting is using different settings as to it’s native format (HDV) it displayed the image perfectly, and when viewing in final cut it viewed perfectly. When the image drops out, there is a remnance of it at the very top of the frame, where you can see a line of colour, this is a very partial section of the actual image displaying. So it seems it just drops out the image from about 2 or 3 pixels down, leaving a flashing line above.
    I am using Final Cut 6.0.5 on:
    Machine Name: Power Mac G5
    Machine Model: PowerMac7,3
    CPU Type: PowerPC G5 (3.0)
    Number Of CPUs: 2
    CPU Speed: 2.5 GHz
    L2 Cache (per CPU): 512 KB
    Memory: 5 GB
    Bus Speed: 1.25 GHz
    If anyone has any advice. It would be very helpful. I know I could export everything to a slightly different format to fix it, but woul rather find out the problem within final cut…
    THANKS!!!!!!!
    Ian
    John Fishback replied 17 years, 2 months ago 2 Members · 1 Reply
  • John Fishback
    June 25, 2009 at 9:29 pm
    I’m not sure I understand your description, but it may be a result of the HDV format. HDV is a form of Mpeg-2 which has dependency between frames. Thus a problem with one frame can affect several following frames rather than just that one. This might be what you’re seeing.
    Try capturing a short HDV clip as Prores and see if it looks better. If you post a short clip, it might be easier for folks to give you feedback.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
