Activity Forums Maxon Cinema 4D problem with spline that fall into the floor!!!!!
  • problem with spline that fall into the floor!!!!!
    Posted by Jonatan Sciaky on October 5, 2018 at 1:48 pm
    hey guys, I’m working on an animation and I started using cinema 4d like 1 week ago and I am having a problem that I can’t solve, I am making a cable using a spline and a circle in a sweep to make the wire and I put a splinedynamic tag to the spline but the problem is that when i start the animation the wire fall down the floor and I don’t understand why.
    do someone know how to fix this problem??? tell me if you need a video of what is happening anfld thanks in advance!!!
    Emir Bojorquez replied 7 years, 11 months ago 2 Members · 1 Reply
  • Emir Bojorquez
    October 5, 2018 at 4:08 pm
    Select the tag, go to Forces >>> Gravity. and change that to 0.0
    Good Luck
    Imagination is the best tool…
