Activity Forums Maxon Cinema 4D problem with spline eflector and text with accents
  • problem with spline eflector and text with accents
    Posted by Benito Sanz on August 22, 2009 at 6:18 pm
    hi.
    i have a problem. when i apply my text to a spline eflector the accents (i am spanish) go into the wrong position.
    any ideas??
    this is what i do in case you didn´t undertand my english.
    text imported from ilustrator, inside a extrude, extrude into fracture object and spline efflector applied to the fracture. my text is distribute along the spline( a circle in this case ). the accent goes in the middle of the second o. the word is conexión.
    thanks in advance.
    Tim Shetz replied 17 years, 1 month ago 2 Members · 4 Replies
  • Tim Shetz
    August 25, 2009 at 5:56 am
    Hi Benito –
    Your English is great…
    When I set up a test like you mention, I get a similar thing. The accent for the O is being treated as a separate object. What is it that you are trying to do with the text on the spline?
    The reason I ask is I’m wondering if the Spline Wrap would work, or are you trying to explode your text into pieces?
    Let me know.
    Thanks.
    Tim
  • Benito Sanz
    August 25, 2009 at 7:34 am
    Hi Tim.
    thank you very much for your reply.
    the spline is in a sphere object ( around ) like the universal titles. and i want them to go around the spline letter by letter till the form the word.
    thank yo very much. again.
  • Benito Sanz
    August 25, 2009 at 6:05 pm
    Hi.
    i did a workaroung and seems to work, but i would like know if it is posible to fix with mograph.
    the workaround.
    duplicate the word and keep just the accent, jejejej, two days to think is that.
    thanks.
  • Tim Shetz
    August 26, 2009 at 10:28 pm
    Hi Benito –
    So you want it to look like this:
    https://www.youtube.com/watch?v=9YCRh23Rg8c
    If so the spline wrap will work…I can explain it.
    Just let me know.
    Tim
