Activity Forums Adobe Premiere Pro Problem with Speech Analysis?
  • Problem with Speech Analysis?
    Posted by Steve Martin on May 31, 2013 at 3:54 pm
    I’m having a problem with the Speech Analysis tool in Premiere CS6. The “Analyze” button in the metadata window is greyed out. I’ve also tried right-clicking on the clip from the project window bin and it’s greyed out there as well.
    I’ve seen a few older posts that suggested it might me a permissions issue on source file being “read only.” But I’ve check that and it looks as though I’ve got read and write permissions.
    I’m on a MacPro running OS 10.8.3
    Footage is on a shared drive (Promise Thunderbolt Raid) attached to a 2012 i5 Mac Mini running 10.7.4.
    Footage was shot on a Panasonic P2 HPX300 using the AVCIntra 50 format
    There is no issue watching, editing or exporting the footage.
    Any thoughts on what I might be missing?
    Production is fun – but lets not forget: Nobody ever died on the video table!
    Steve Martin replied 13 years, 3 months ago 2 Members · 2 Replies
  • Vince Becquiot
    June 2, 2013 at 5:37 pm
    Hi Steve,
    Make sure those permissions are on all folders, from the CONTENT folder to all subfolders and files.
    That should do the trick.
    Vince Becquiot
    Kaptis Media
    Indigo Live
    San Francisco – Bay Area
  • Steve Martin
    June 5, 2013 at 10:16 pm
    Hi Vince,
    I checked every file in the contents folder/subfolders and everything was set to read/write. I’ll try moving the files across the network onto a local drive to see if that makes any difference, but if there’s anything else i can check, I’d welcome the feedback.
    thanks,
    Steve
    http://www.OmniNewMedia.com
    http://www.GreenSlateStudios.com
