Activity › Forums › Apple Final Cut Pro Legacy › Problem with Sony DSR-25
  • Problem with Sony DSR-25
    Posted by Carlos Ortega on August 6, 2010 at 9:17 pm
    Hey guys, I’m trying to capture footage in FCP using the input on a DSR-25 deck and I’m not getting any display in FCP. It works fine if I’m trying to capture from a tape inside the DSR-25 but it will not work with another device connected to the input jack on the DSR-25. Any help would be greatly appreciated. Thanks!
    Carlos Ortega replied 16 years, 1 month ago 2 Members · 2 Replies
  • Chris Babbitt
    August 6, 2010 at 9:45 pm
    You have to select “Non-Controllable Device” under Device Control in the Log and Capture Window.
  • Carlos Ortega
    August 7, 2010 at 2:37 am
    Thanks for the suggestion Chris, I tried that and it still doesn’t work.
