Activity Forums VEGAS Pro Problem with slow motion and stabilizer with vegas 12.
  • Problem with slow motion and stabilizer with vegas 12.
    Posted by Marius Socaciu on June 16, 2014 at 8:05 pm
    I have a problem using Vegas 12.367:
    when using slowmotion (built in playback rate) in conjunction with stabilization (sony vegas stabilize plugin) i get a shaky footage like in this youtube video at point 4:
    I have used:
    1. orginal footage / smart resample on
    2. Playback rate 0,5 / not stabilized / smart resample
    3. Playback rate 1 / light stabilization / smart resample
    4. Playback rate 0,5 / light stabilization / smart resample
    5. Playback rate 0,5 / light stabilization / disable resample
    The best result should be 4, but it aint.
    The original file can be downloaded at: https://www.fotosmiley.ro/stuff/00127.MTS
    Am i missing something or there’s a bug in Vegas?
    Marius Socaciu replied 12 years, 2 months ago 4 Members · 10 Replies
  • 10 Replies
  • Steve Rhoden
    June 16, 2014 at 8:58 pm
    Try stabilizing and render out that bit of footage first,
    then drop it back on the timeline and continue with your usual edits.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Marius Socaciu
    June 16, 2014 at 9:05 pm
    that’s a good ideea… but it’s so much work for nothing 🙂
    i see now that youtube hasn’t shown my problem so the rendered file with the problem is: https://www.fotosmiley.ro/stuff/stabilizer_problem_vegas_12.m2t
  • Steve Rhoden
    June 16, 2014 at 9:18 pm
    No, its not for nothing. If you want detailed precision in your
    work its worth it at times. That’s why you charge clients for your
    work. If it was easy they would do it themselves.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • Marius Socaciu
    June 17, 2014 at 5:32 am
    Steve, you are right, it’s not for nothing, because the results are beatiful! But i guess Sony didn’t had that in mind when they wrote the code for the program.
    I will try to update Sony Vegas and see if this still happens again.
    It’s pretty annoying to add stabilizer effect from media fx already. But to make a new project and render it for every file that would need stabilizing for a slowmotion effect in the base project, it’s almost too much. And nonsense!
    I will come back
  • Marius Socaciu
    June 17, 2014 at 7:01 am
    It’s confirmed, same happens whit latest build of Vegas 12. Shaky image when stabilizing in conjunction with slowmotion.
    I’m blown away by this. Still hoping that i’m doing it wrong, but it seems like not.
  • Steve Rhoden
    June 17, 2014 at 3:00 pm
    Marius, personally still when i am stabilizing an event, i dont even
    bother to look at the built in stabilizing feature of Vegas, its
    inferior and a cut down version of Prodad Mercalli.
    What i use and the utmost best is the Prodad Mercalli plugin itself.
    Outputs excellent results. So if you have the resources and need, that
    is what i recommend you to get, You wont have these issues anymore.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • Marius Socaciu
    June 18, 2014 at 10:17 am
    It seems that After Effects cant either do stabilizing in conjunction with slow-motion, so if we want to use both effects on the same clip we have to do them separately or use third party stabilization.
    Thank to those who replied.
  • Edward Troxel
    June 18, 2014 at 4:15 pm
    If I have clips that need stabilizing, I would ALWAYS add only Stabilizer, get the settings correct for that clip and then render out a new stabilized version. Repeat that for all clips that need to be stabilized. Now finish your edit using these new stabilized clips. Sometimes it’s best to do things one step at a time.
    Edward Troxel
  • Aleksey Tarasov
    June 18, 2014 at 4:58 pm
    Prodad have another standalone tool – ReSpeedr, which can slow down and stabilize at the same time, but their Mercalli is the best to stabilize footage.
  • Marius Socaciu
    June 18, 2014 at 5:34 pm
    Edward, when working with 4 hours of footage and having to stabilize at least 20-30 clips, it’s a little hard to stabilize each clip separately. That’s why there is a timeline with multiple clips and layers on it, to benefit from it! Sony has done a nasty job and I can’t imagine a reason for doing it! But if that’s how thing are, we always find a solution!
    Sooo… I tried Mercalli Stabilizer, v2.105. It does it’s job better than sony’s own stabilizer. And works with slowmotion like a charm.
    In general seems like interlace footage is a little off hand for stabilizers. I shoot with a Sony NX5 witch gives me 50i interlace footage, and from here all the problems.
    Anyway,
    Thanx to all who have written. Happy editing!
