Activity Forums Adobe After Effects problem with scatter in Element 3d
  • problem with scatter in Element 3d
    Posted by Ali Khoshdouni on September 2, 2012 at 9:28 pm
    When i use two 3d models in 2group in the element 3d plugin i have a problem with the scatter in enable multi ubject for group 2.
    in fact i active stopwatch for animation engine then use 2 keyframs in 2 different times. enable the multi-object in group 2 . then increase scatter but not seen any shatter effects in 3d object.
    Walter Soyka replied 14 years ago 2 Members · 1 Reply
  • Walter Soyka
    September 3, 2012 at 4:09 pm
    Multi-object in Element 3D for 3D objects only works if they are pre-fractured. You need to use your 3D app to break your one object into separate pieces of geometry, not a single unified object.
    Walter Soyka
